Metro PCS has 3G now!!!
I was able to use a program called QPST v2.7 which is like CDMA Workshop but free to do this. I'm not great at making guides but I'll just tell you what I did.
Here is the QPST I use and the PRL. I'd love to give credit to whoever originally obtained the PRL but to be honest I don't even remember where I got it. It is safe tho and works,that I can assure.
Free File Hosting Made Simple - MediaFire
1. Installed QPST.
2. From the start menu I found the QPST folder and started QPST Configuration
3. Had my Ascend connected and opened Device Manager and expanded the Ports icon. I took note of the COM number listed beside the DBAdapter Reserved Interface,which in my case was (COM15)
4. In QPST Configuration I clicked Add New Port at the bottom right and selected the COM15 and enabled it.
5. After that I went back to the start menu,QPST and opened Service Programming. A box popped up asking for a phone and since I only had the one I just clicked OK and a new box with alot of tabs opened.
6. If you go to the Roam tab at the bottom there is a Preferred Roaming area with an area asking for a file. Browse for the PRL and when finished click the Write to Phone button at the bottom of the window. It will ask for your SPC. After that it writes to the phone and the phone reboots on its own. You should let it reboot fully and not unplug it from the computer or mess with QPST while it's doing so.
When the phone is done booting you can close the program and unhook the phone. It took about 10 minutes for data to start working but 3G works fine on it when I'm in a 3G area. My Ascend is using the bloatware free stock 2.2 ROM found on here and I've had no problems for the week with it. Hopefully this can be helpful for someone and sorry if it's not made out too well,pretty bad at explaining things :P
Follow this. Its the one I followed.
Oh and here. To find out your SPC.
https://market.android.com/details?id=com.splicedmedia.android.meidconverter&feature=search_result
So I had update my prl myself to 3022 like a week and a half ago now I check and I have 3023 which I think was OTA cause I didnt do it so awesome!!!!! I think they starting to update the phones network more aggressively now alot of people I knew didnt have 3g like a week ago have it now.. so if u know there is 3g in your area just wait a bit but if ur a risk taker like me do it yourself..plus u think its hard but its not follow instructions and u will Get It!!!!
In Clearwater/Largo, showed 3g under 3019prl, updated listings, now waiting for restart to see if it switched to a different prl, or stayed at 3019. That was weird..PRL stayed at 3019, and no 3g...
i got 3024 on my phone, has anyone got it?
Uhhhh wheres Nutmegg? Ahaha Im not sure how to do it with QSPT but heres how with CMDA Workshop. Nutmegg knows how to do it with QSPT tho...I think
If anyone with the 3022 PRL wants to pass it along to others heres how.
I will post this guide which works for most android phones..let me know if it works for Ascend..you will need a program called CDMA WORKSHOP 2.7, I can't post the link here. You will also need to have the ascend usb drivers.
Download and install usb drivers for Ascend from here: ascend_usb_drivers.zip
On Phone Dial this code
*#*#2846579#*#*
A menu will pop up
Then
Go to projectmenu -- Background Settings -- USB Port -- (select) Manufacture mode
Then
Go To settings -- About Phone -- Status -- MEID (write down your MEID)
GO to whiterabbit's android site and enter your MEID and click on CALCULATE and this will give you your metro SPC code, write it down. android - whiterabbit.org
(You can skip all of ^^^^^^ that if you download the MEID Converter off the Market. Its free"
Make sure on Phone USB Debugging is on
Now On Windows go to device manager -- ports -- DBAdapter Reserved Interface
(Remember your COM PORT)
Now open CDMA Workshop and choose the port you took note of earlier...click connect. Open the security tab and enter the SPC in the box and click SPC then send.
Now go to Other tab and under the PRL section click on READ (Universal, NAM1), this will let you save the PRL to a .prl file on your PC. Save it and upload it here .
Let me know if this works for you if not PM me with your error codes.
I just got 3G again on the 3019 and for the first time ever at my house. Ahaha
Ran a speed test:
Ping:190
Upload:703 (Holy shit! Ahaha)
I actually have the 2024 PRL, it just appeared. It was at 3019 yesterday. So I'm not sure what the deal is. I'm running on an altered version of Froyo 2.2, I just took out the bloatware with Root explorer.
3024?? cool. Can't wait for the upload. I'm running out of things to do with my Ascend so trying a new prl will make my day. LOL
BTW how's battery life for the rest of you with the 3g? Mine is crappier than ever so I am forced to turn off data when I'm not using it. Otherwise my battery is dead in around an hour, seriously... But I'd rather have to keep my charger within arms reach all day than go back to 1x...
I'm still running on 1x even with 2024. The only time I get 3g is when I go to cocoa beach. I'm north of daytona beach.
Currently on 3024 (thanks for the upload)
Download speed still around 180-195kbps
Upload speed up to around 605kbps
i have the one straight from the ascend, i know im late, but havnt been around in the last few days, had alot going on, but all is good, and if someone wants the one from the ascend just let me know, but im sure the one from the optimus will work also.
