J Jacex Member Mar 26, 2012 #1 Where can I find the default wallpaper for my metro PCS? Can it be removed?
S SpawnHyuuga Well-Known Member Mar 26, 2012 #2 I wouldn't recommend trying to remove it. If I remember correctly, it exists within SystemUI.apk which means it could be replaceable. I have not tried myself, however.
Primed Well-Known Member Mar 27, 2012 #3 It's located in the framework-res.apk, and can be changed, but probably not without knowing a little bit about android first.
