Help Metro wifi/gps shortcut
lexbot
Anybody know which app to remove to get rid of this thing? I don't mind it so much, just would like to know. Thanks. :D
Those are icons from Metro Easy WiFi, to get rid of them, root and erase app from system.
Strange, easyWIFI was one of the first apps I removed, yet I still have this toolbar. As far as I can tell I have removed every app with the name "metro" in it.
Thanks Mike, I just double checked and I definitely removed that one. Not sure what I missed. You were able to remove the toolbar at the top?
LG Optimus has his own Sat and WiFi icons, they use to be on the Toolbar when are active. Metro EasyWiFi has another ones (red coloured) that use to be on the left side of the Tolbar. Which ones are you talking about?
Ah ok yes I am talking about the the Sat/WiFi icons on the top. They are present for me always. I actually kind of like them, just curious to know which app they are.
One is from the stock WiFi app and the other from Sat app.
You can disable WiFi in Settings- Wireless Networks- WiFi settings
To disable Sat is in Settings- Location & Security- Use GPS satellites.
Ok, maybe I still wasn't following on which icons you meant.
I mean the row of 5 icons that reveals when you pull down on the bar.
It has:
volume
wifi
bluetooth
gps
airplane mode
It has:
volume
wifi
bluetooth
gps
airplane mode
Oh I see!!! They are quick launch icons, with them you can enable/disable with just one tap the volume, wifi, bluetooth, gps and airplane mode. I like them a lot. When go to a meeting just tap volume and got "vibrate only" with just one tap, same thing when I'm driving turn on bluetooth (to sync with my car) and turn off wifi (for saving battery) ;)
