alcala1219
Alright Im stuck at the LG logo. First off Im rooted and have made a backup. (which has worked on a previous soft brick) Now i deleted some apps that I later decided I wanted so i figured I figured i would just re-flash my backup, now everything was going fine, /old boot being deleted/ flashing backup/ failed to install backup!! Now I have nothing. I can boot into "hard reset" mode and download mode but now CWM. I am going to give this a shot,
http://androidforums.com/tmobile-op...ck-unroot-complete-stock-updated-11-20-a.html and see where this gets me. Is this doable or is there another way to get into CWM and use my backup
Thanks
also i tried using lg support tool and it keeps telling my that my battery is too low and to recharge and try again. Battery is at 100%
Thanks
