Root [MetroPCS] can't mount data!
paco4315
When i try to do a restore using cwm recovery it says can't mount /data but it successfully flashes the rom. How do i fix this and is there any way i can get my data back?
Don't boot into recovery by doing an LG Factory Reset
Boot into recovery via ADB or your ROM.
LG's Factory Reset wipes and corrupts the /data partition.
