Root [MetroPCS/CDMA] AOKP vs CyanogenMod
What aare you rocking on your gs3;)
  • Total voters
    25
  • Poll closed .
Right now. Cyanogen. 4.2 is still under construction and the cm people are doing the constructions. Even after the release of m2, there has been hella improvements made. When it looks like the only improvements left are only cosmetics then, I will wait for an aokp that's built off it and try it out cause they do add some useful features.
P. S. This goes for all 4.2 roms. Because from what I've seen. All of them are built off cm10.1.
I use the CM rom - it's simple and smooth.
The only thing I've noticed is that sometimes (after flashing a new nightly) pressing the home button will show the tasks (which should only happen when long-pressed) instead of taking you home. It's kind of frustrating, but it seems to happen on almost every other nightly.
I don't know if I'm the only one this happens to. :bebored:
just curious guys what is the difference between these two rom's, which is your, favorite, and why?
I use baked beans when I go outside of stock. It has a few xtra theming gadgets, & I think its tweaked better for smoother & faster service.
That's happened to me too. It happened to me yesterday on AOKP. :eek:
It isn't just the home button for me. When this happens all buttons act like a long press. Volume goes from min to max with one button. Quick reboot is a temp fix.
I also use the BAKED ROM.
I've had the same problem lonestariot with every CM10.1 ROM I've run. It will randomly start and stop for me.
I haven't tried AOKP so I'm not sure which is better, but I like CM because its customizable, smooth and in general just works for me.
In all honesty I hate numerous options.
Hard to read because text based answer. Twas a sarcastic comment. Just make backups and flash em all. Try them all out. Everyone has their preferences and you won't know yours till u try it out. Happy flashing bubba.
I like em' all. :p
Same here....Never met a ROM i wouldn't flash...Like a woman in a shoe store...bring 'em all on...daddy wants to try them all...
I usually get my phone set up exactly how I want when another badass ROM gets released. First world problems.
Well it does appear that the changelog for cm10.1 has been mostly superficial for the past few days. I will be trying the next baked or aokp build. Can't wait.
I'm digging the PACman ROM.
ParanoidAndroid+AOKP+Cyanogenmod
Sexieness.
Confusing at first .. but sexiness awaits.
