ROM toolbox will work for you.
what i want to do is transfer the boot.image from one rom to the one already install on the phone.
Oh...Why would you want to do that?
he didn't say boot animation cuz the actual boot.img is something you dont want to mess with.
Thanks I'm on goodness rom debloated.and the boot up image is just the word android.so I would like to change it to something more nice looking.
He is talking about the bootanimation, i should know that's what i'm using
The boot animation for majority of the roms is a zipped folder called bootanimation.zip not boot.img on stock samsung roms the real boot animation is samsungani im not sure where you guys are getting boot animations from a specific important file which contains the kernel to our device called the boot.img im not being a jerk here but if your going to discuss something or ask for assistance try to be clear of what your trying to achieve and what files your looking for if your not sure how the file is called just give a brief description. we are here to help.
Edit: with that being said navigate to system/media and see if you guys have a zipped folder named bootanimation.zip if you dont you guys are using the stock animation method which plays qmg images. its fairly easy to get a stock system to use custom bootanimation.zip files instead of the qmg.
sorry about the confusion. what i meant was the the boot up image like when you turn your phone on like on factory roms it says metropcs or other roms have custom images at start upuntil the phone is actually on. well thats what i want to change.
ok did u check to see if your rom has bootanimation.zip at system/media like my pic shows? if so lol changing it will be too easy.![]()
