Rickinfl
Member
I just wanted to start this Thread because I was talking about this in CM10 and I wasn't on it anymore plus some other people had the same problem and were following me and I didn't want to clog up the CM10 forum.
Description: Screen is very dim to the point you couldn't hardly see anything and when you turn it on and if you slide to unlock the screen would go black also very dim while getting a phone call you couldn't answer the phone at all. If you keep hitting the power button on and off the screen would eventually come on normal.
Well I tried CM10, Blackbean, AOKP and all did the same thing. I reinstall (Wiped everything) and still same problem. I tried turning off Lock Screen, switching from auto dim to manual. Tried turning off WiFi. Everything I tried didn't work. I switched back over to Stock ROM yesterday and it works perfect now (Well So Far) lol I had more trouble at work than at home it seemed, but then again I used it more out than at home.
I'm going to give it a couple of days and see if it acts up. If not than I'm going to start from Scratch with just CM10 and not install anything in case it's something I was bringing over from Stock ROM. I have no clue what's going on but by breaking it down by steps I might find it. Now I'm on stock and have no issues that rules out the phone being bad because I started to think the phone was the issue now I know it's not. (So far)
:laugh:
