firenemesis7
Has anybody successfully flashed a us cellular phone over to metro PCs. If so how hard is it to do and is it something I could do on my own or would I need a cell company to do it
I would like to know too. I'm waiting for the note 3 to come out for usc and woukd like to be prepared.
In the meantime I guess you can try and odin shabbys return to stock tar and dial *228 and see if it will activate.
The problem would lie in getting the ESN into metros database. I have never done that before. I was thinking about picking up a note 2 or an extra s3 to try it but not sure if it is something that is doable.
and trust me alot is not being said due to what forum policy allows us to say so take that into consideration![]()
. it used to be all over xda.the changed law was you cant unlock devices to use on other networks, which has never been an issue for cdma... because you never could.. gsm people that travel internationally have every right to freak out as they now need to buy a factory unlocked device at full price instead of just unlocking teh att branded device they already have (unless att is kind enough to unlock it for them)
with cdma devices the phone idenitfier number (what the network says the device is) is permanently software embedded onto the device and unless you can get a carrier to add that number (ESN/MEID) to their database of devices then you arent gunna get service from them. most carriers will tell you too bad and t o buy a phone from them, the only way around this is a legally grey area where you take the esn of one phone, and put it on another.....
for instance what i was going to do was buy a lg motion 4g, take the information i needed from that device and the uicc. put it into the uscc sgs3. once the ESN is on the sgs3 i call up metro sign up tell em i have a lg motion etc etc activate it as normal get my subscriber info from them for data/mms and that alone will promise me calls/data/sms/mms all on 3g.
as that is ESN manipulation and thus carrier fraud its a topic that is usually kept in teh darker parts of teh web. but that new law has nothing to do with it, t his was already illegal before that.
yea being able to get this working would do more than just bring newer devices to metro. if this worked then cricket may be possible. and they are a prepaid service so you have to buy teh phone outright, and well... look
https://docs.google.com/file/d/0ByCeTYQz0C-9dFNjYUNxd2ZWTlE/edit
its 379 bucks for a brand new sgs3. now i cnat confirm or deny that eitehr carriers would work, as i believe if any were to it would be uscc's but crickets may as well and if so that would be a cheaper place to get sgs3's for metro. especially since i have a dealer contact for cricket/pageplus
the crappy part is we wont know until someone takes that 300-400 dollar risk though :/
