Root [MetroPCS/CDMA] Help! GF just got a New S3 and having problems
Rickinfl
Member
Hi, My GF got a S3 from Metro PCS and she can't call out or receive calls and can't get a hold of anyone at Metro PCS to help her. Does anyone know someone she can contact? or a number she can call? She just got the phone.
Thanks,
Rick
That's strange try this number helps alot 800-901-6266 you can also active it on you're own by dialing 611 i believe..
*490 on stock ics with metro bloat ware opens a app forgot which app you gotta disable first. metro connect i think dunno.
Still not sure if I wanna root my new pet or not
Root is very easy to put on and even easier to uninstall. A lot of people don't realize that root just a apk installed on your system. It does need to be installed through scripts but uninstalling it is so simple.
yeah I know rooted ever android I've ever had and my family's. I don't know it just seems so good the way it is but ill probably do it maybe Sunday
