Root [MetroPCS/CDMA] [MOD][Big Weather Lockscreen Mod v1.2.0 and v1.1.0.1]
ARocker
Android Expert
Big Weather Lockscreen Mod v1.1.0.1
Stop Squinting!
Please backup your phone before flashing this!
Flash at YOUR own risk!!!
Big Weather Lockscreen Mod v1.2.0 is a Modification for Metropolis Rom 1.2.0 by Shabbypenguin in association with (OUDHS).
Big Weather Lockscreen Mod v1.1.0.1 is a Modification for stock versions of MB2 including Metropolis Rom 1.1.0 by Shabbypenguin and [ROM]{D2mtr} Stock/Root/ODEX+DeOdex MB2 by Ldrifta.
I have not created any of the images or files used in this mod although a few have been edited.
New versions remove AMPM from lockscreen, changed font color to white and unbold.
Big thanks to Shabbypenguin, Ldrifta, and all of our devs and contributors!
Thanks to KIMBASINGER for his great tutorial
This is their work, if you like it, Donate to and Thank them!
This is my effort, if you like it, hit the Thanks Button and Rate the Thread!
It works on my D2MTR, it should work for yours too.
I hope you enjoy it!
Screenshots:
Before
After
!!!Warning!!!
Version 1.2.0 will cause issues with stock deodexed MB2 roms and is only meant for Metropolis 1.2.0.
Version 1.1.0.1 and version 1.1.0 should work well with most stock deodexed versions of MB2.
This zip will replace the folowing file:
framework-res.apk
!!!Warning!!!
Flashing this will untheme framework-res.apk
Do not flash a theme that includes a framework-res.apk as it will overwrite the mod.
Remove the framework-res.apk from the theme before flashing.
These Mods are for Touchwiz MB2 based Roms.
Installation Instructions:
-Copy Mod [Zip file] to sd card
-Boot to recovery
-Make Backup!!
-Flash Mod [wipe Cache & Dalvik Cache]
-Reboot & Enjoy
Updated OP with links to New version!
Thanks to all involved in making this community great!
Thanks to our Mods Guides and Devs!
Thanks to the ghost ninjas!
Thanks to all that thanked me, I appreciate your support!
The rest of you suck :)
