Root [MetroPCS/CDMA] Not Necessarily Root... i think
Im trying to theme my phone and i need to put files into a market place app. however i cannot find the app in the internal memory and i think thats because samsung hid it possible. anyone know a fix. My s3 is rooted anyone know a way to help
Apps are installed on data partition. Look in /data/apps with root explorer or something similar.
1. Place .mtpref files from HC_Text.zip in the MinimalisticTextPreferences folder in your sdcard directory.
2. Place 'home—1358621776.xml' from Fonts.zip to the Simple Text/styles folder in your sdcard directory.
3. Place the 2 Roboto fonts from Fonts.zip into a folder that you use for fonts (might have to be a sub-directory)
4. Place both Image folders (you must extract them) onto your phone, as you will be needing them for wallpapers, etc.
This is what i need to do but i cant find the prefrence folder
That sounds like a pretty complicated theme app. I'm assuming once you install it, it creates those folders in your storage.
If you can give me the link I can try it out and let you know what I find.
So youve got to install 10 apps (9 if you already use that launcher) to get it to look like that.
Not worth it imo.
its really not that hard to setup and the apps are nly text editing apps and widgets lol im just stuck on putting the file in the right place
