Root [MetroPCS/CDMA] [ROM][B1] King Kang Build 1 - Unleash the Beast! [AOKP + CM10 + ParanoidAndroid]
Shabbypenguin
Extreme Android User
What is King Kang?
King Kang is essentially a hybrid ROM - its a mixture of AOKP, CyanogenMod, and ParanoidAndroid, bringing all their customizations to one rock solid and quick ROM. These numerous features combine to create a blend of features not seen anywhere else before. Make the user interface yours with this ROM. Change the DPI the ROM runs at, tweak the interface to your hearts content, while enjoying great battery life and stability. Never before have these features combined to create a ROM as feature-packed as King Kang. Credits for the features goes directly to the teams responsible - AOKP and CM for their respective work, and ParanoidAndroid for their wonderful DPI on-the-fly modifications. Without these teams, this ROM would not be possible.
What is the future going to be like for King Kang?
Currently, it is heavily rooted in AOKP as its main base. As the ROM progresses, it will grow and extend its functionality. Want to see a feature from a different ROM that isn't here, or have an idea for a new feature that isn't currently in any other ROM out there? Fill out the feature request form located here so that we can bring it to you! http://kan.gd/1t88
What are the current features of King Kang?
  • All of AOKP's features
  • ParanoidAndroid per-app DPI changer
  • Apollo music player from Cyanogenmod
  • CMs Backuptool when flashing
  • More is coming soon! Feature request here: http://kan.gd/1t88
How do I install King Kang?
  • Download the ROM from the box below
  • Download the Google gapps from the box below
  • Reboot into your recovery (TWRP is recommended)
  • Wipe data if you are coming from a ROM besides King Kang
  • Flash the King Kang ROM zip
  • Flash the Google Apps zip
  • Format your dalvik cache/normal cache
  • Reboot
  • Customize your experience to your heart's content!
Download
ROM: KingKang-B1
Google Apps: Gapps
Gapps for Jellybean (4.1.2/CM10) should work perfectly, cant promise if 4.2 works
Information
Some AOKP features power over the ParanoidAndroid ones. For example, in order to get Tablet UI, you first need to check the "Tablet UI" option in ROM Control, then change it to the desired mode in Paranoid Android, and then reboot.
This ROM began as a creation by DAGr8 for Android 4.0, ICS. It offered a simple AOKP + PA combination.
Contribute
Want to get involved in the ROM? Grab the ROM source, located here: http://github.com/KingKang
Donate
Do you like my dedication to this community? Want to show your appreciation?
All donations are greatly appreciated!​
Thanks
  • DaGr8
  • rohan32
  • AOKP
  • CyanogenMod
  • ParanoidAndroid
i said i wouldnt do paranoid android, but wanted to give yall per app dpi settings :)
enjoy phablet and tablet ui's guys :)
Does it work well?
cmon man have you seen my work? im not a fan of having crappy stuff out there. at least not without a label of it being crappy and not working :P
afaik this rom is working fully, n4zty is my faithful tester and he said all the core stuff is working, hes running thru the dpi settings now im getting screenshots from him while in phablet mode :)
no this is 4.1.2, 4.2 gapps might work but i cant garuntee it, sorry i c&p their OP and edited it didnt think about teh gapps reference
dam shabby u out did urself does bor nice from wat i see G imagine if touchwuz was on there it could be like omega rom only customizable=o
while you cant get true touchwiz on aosp based roms there is a touchwiz launcher you could use.
also i apologize to everyones wives/girlfriends for ruining their nights. i was bored and wanted to do another rom, ill try to make sure it doesnt happen again ;P
true true it is wat i use for the other roms nd hey n4sTy is ur tester right has he reported any rebooting issues??
Shabby i just thought of something how come u dnt pimp out a touchwiz jelly bean rom bro=o
o and hey have u looked into the wifi direct if it was possible to add into a aosp rom?
i plan on doing a nice touchwiz ics rom when i get the phone. cant do jellybean as you guys dont have it, the phones that do have it are based on leaked builds
and wifi direct is not possible its a licsensing issue, if i did i could be sued
Ok this ROM is working flawless for me I've MMS Mikey and he's gotten my pics um let's see the ui interface works great it changes modes flawlessly keep in mind every change requires a reboot. The tablet mode and phablet mode looks a lil strange that's because I didn't bother changing icon size. It does have some presets preloaded for each mode so that's cool. Other cool stuff? I guess I'm still playing with it ;)but since shabby released this early I'm sure ya won't have any prob finding new features :D post back any findings!!!
For any new comers that wanna try this ROM back up current ROM then wipe/factory data reset then install this ROM and flash gapps then wipe cache/dalvik and reboot!
Sweet bro but wait werent u gonna try to port a omega rom or tht other jelly bean rom tht was for the sprint version cause i heard the omega rom is best jelly bean touchwiz rom since it has multi window and other shit
Don't ya forget to keep donating for shabby's gs3 he's working blind here I'm working as his eyes!!!! Let's get shabby on the gs3!!!!!!!!!
