Root [MetroPCS/CDMA] [ROM] NumberTwo v1.5.2 | NA1
LDrifta
No Stranger 2 Danger
D2mtr_NumberTwo_ROM
~This ROM is for rooted devices ONLY, flash at YOUR own RISK!!!
Special Thanks:
@ShabbyPenguin - Help/Guidance
@PlayfulGod - Help/Guidance
@nuttmeg - Mods/Additions
@ARocker - making life a lil easier
@majdinj - fr many seful guides
@ktmdave7 - CSC feature list
@All Testers & Users of the #2 Rom ;)
Need Help Rooting? check this out!!
[SGS3-R530M] OUDHS Recovery 1.0.3.3 & Root
Rom Base:
NA1 Official Release (4.3)
Kernel:
LeanKernel v4.0 (4.3)
Rom Features:
-Root & SU
-KNOX Free
-Busybox & init.d support
-DeBloated
-DeOdex'd
-Multi Window All Apps
-4-way reboot MOD
-trans Weather Widget
-4x5 Homescreen
-Launcher speed hack
-360 rotation
-Message share, save and restore features enabled
-MMS Split-view enabled
-Shuter sound option enabled
-Call/Msg Block feature enabld
-Removed software update option from 'About'
-Extra cleaning process via install script
-Build.prop tweaks See Notes
Notes:
Build.prop additions:
# Battery Tweaks
pm.sleep_mode=1
power.saving.mode=1
ro.config.hw_power_saving=1
ro.ril.disable.power.collapse=1
wifi.supplicant_scan_interval=300
#Other
dalvik.vm.verify-bytecode=false
dalvik.vm.dexopt-flags=v=n,o=v,m=y
ro.kernel.android.checkjni=0
ro.kernel.checkjni=0
ro.config.nocheckin=1
profiler.force_disable_err_rpt=1
profiler.force_disable_ulog=1
Download Links:
NA1: 4.3
*Thanks to shabby once again for the help and the know-how to get us what we need
KNOX FREE, CAN be installed on MF2 Bootloader!!
D2mtr NumberTwo v1.5.2 - based on the NA1 firmware (4.3)
D2mtr_DeOdex_ReBloater - restores all app's I personally removed xcept knox related
Custom Boot Animations: 4.3 ONLY thanks anbech: source
*This file allows you to use custom boot animations, but it disables the stock Samsung boot animation, so I provided a disabler as-well if you want to use custom Samsung boot animations, or you like metro's... :/
D2mtr_Cust_Boot_Enable - allows you to use custom bootanimation.zip files in system/media
D2mtr_Cust_Boot_Disable - sets boot style back to stock
MF2: 4.1.2
D2mtr NumberTwo v1.4.4 MF2 - - - -Latest (Full Rom)
My Metro & Visual VoiceMail - - - - - Exactly what it says
Stock Music Player - - - - - - from Elegant Theme, thanks to ARocker
Installation Proccess:
*If you are flashing 4.3|NA1, you MUST have the 4.3|NA1 Modem Installed found here:
[SGS3-R530M] Modem Repository
-Download ROM and copy to SD/Storage
-Boot to Recovery mode
-WIPE DATA IF YOU'RE A FIRST TIME USER!!
-Flash/Install ROM
-[Optional] Flash Add-ons
-Reboot & Enjoy!!
ChangeLog:
1.5.2 - sorry but you will need to wipe data for most new features to work :/
-Updated MOST system apps
-Added a few nexus 5 sounds
-edited build.prop (much bttr now)
-Launcher Grid 4x5
-Full 360 rotation
Change Log continued...
1.5.1
-minor edits to installer-script (extra cleaning precautions)
-minor edits to build.prop (removed sme un-trusy lines)
-removed two more knox-related apps I missed [ContainerAgent(s)]
-removed boot sound (just didn't fit...)
-added intl official Sammy boot ani
-removed some of the larger sized ringtones...
1.5.0
-Updated to NA1 Firmware (4.3)
-DeBloated & DeOdex
-4-way reboot mod
-multiwindow all apps
-trans weather widget
-Note3 MyFiles
-build.prop edits (battery)
1.4.4
-Put Chrome and sync adapter back in
-Removed some un-needed tweaks
-added multi window fix to rom
-more? (small stuff)
1.4.3
-Removed web/browser related csc mods*
-YouTube Fix
-App Issue fix (build prop adjustment
-S-Voice fix
-Multi-window fix
v1.4.2
-build.prop back to orig 1.4
-much aosp theming done
--settings, contacts, phone, mms & framework--
-100% battery mod
-added split mms
v1.4.1
-re adjusted buid.prop tweaks
-re added some csc customizations (see notes above)
-new theme aditions thanks to arocker and a few others
-new launcher 4x5 (need to fix landscape mode sorry)
-running fast & smooth, enjoy :D
v1.4
-Updated to MF2 Base
-4-Way Reboot
-Smooth Scroll
-S4 trans Weather Widget
-Note2 Cam & Gallery
-Updated Hosts (AD-Blocker)
-Pop-Up Browser
-StatusBar Theme
v1.3
-Updated to new MD3-Leak as ROM Base
-CSC Stuff (MMS, Settings, Camera, Web)
-Settings Status= Normal
-Multi-Window ALL APPS
-Build.Prop Adjustment
-Unsecure Boot.Img
-Pop-Up Browser
-Launcher MOD
-4-way Reboot
-Updated Hosts file (ADD-Blocker)
-S4 Weather Widget
-StatusBar SysUI Themed
-Removed keyboard icon
-StatusBar open/close speed up
-MMS Mods (split view for landscape, group msg, save/restore, scheduled msg)
-Much more to come...
v1.2
-Multi Lockscreen
-Ink Effect
-Hosts file update
-Themed Power Menu
-New Weather Widget
-Multi-Window
-more I forget..
v1.1.1
-Multi-Window added as "Add-On"
-Fixed Installation Issues
v1.1.0
-Added Multi-Window (Thanks Shabby & his team, GruesomeWolf & the nocturnal crew etc..)
-Added Transparent Weather Widget
-Added S_Translator
-Added Ripple live wallpaper to Build-a-Pack
-Added Note2 Camera & Gallery
-Added/Option 4.2 Camera & Gallery
-Volume rocker mod (came with multi-window)
-Number Two decals on lockscreen and statusbar
-Removed default bookmarks and set homepage of SecBrowser to google
v1.04
-Removed Aroma Completely
-Added Essentials Pack
-Added Build-a-Pack
-Re-Added AOSP Lockscreen
-Added Modded MMS thanks ARocker
-New Boot Animation
v1.03
-fixed ALL AROMA issues
-fixed auto-rotate issue
-removed aosp lockscreen due to auto-rotate issues
-removed some build.prop tweaks for the better
v1.02
-updated some apk's
-updated rom customizer
-removed a few more thing from rom and placed into customizer
-added 4.2 app & launcher options
-fixed launcher installation issues
v1.01
-ROM itself does not use AROMA installer
-Added the 'ROM Customizer.zip' which IS an AROMA based installer to add/select which features & tweaks you would like to include in "your" ROM
-Fixed freezing issue after install
-re-organized the installation proccess
-adjusted some tweaks tawards a better battery usage
-few new options added to the ROM Customizer.zip
-ROM base itself is SUPER DeBloated
v01
-fixed installation script
-fixed/adjusted build.prop
-added launcher options during install
-cleaned up the aroma
BETA
-first release
Screen Shots: MF2 Only (for now...)
Loved this rom on my connect. Do you have plans to add the volume rocker to change mp3 tracks mod to this. Much thanks btw downloading now...or will when it's done uploading.
i have plans on adding many things.. lol but enjoy for now, everything 'should' bee 100% for the time being haha
O_O i was planning to flash this in a while...if im on aokp are there any different flashing instructions(due to the my current rom being aosp)...or do i just flash it due to the installer script...
Is there a trick to enable aosp lockscreen? Tried just checking the option, tried rebooting, tried turning off all other options and rebooting. Looks good other than that. Smooth and no fc whatsoever.
Thanks
Btw...really like the aroma installer option to add/remove what you dont use or want. Thats very nice. :)
Any advice on the lockscreen not showing?
