Root [MetroPCS/CDMA] [ROM][OFFICIAL] CyanogenMod 11 Nightly Builds for d2mtr
I fixed permissions and "apps and adb" was already chosen, still no root. installed another superuser and it tells me su binary not installed
just to be sure..the developer option is the one labeled "superuser" in settings, right?
I'm on cm10.2 android. So what's new in android 4.3?
Bluetooth 4.0 for battery life, open gl3.0 for better gaming, WiFi scan only mode that improves location accuracy and helps battery life, restricted profiles, and I've also heard that ram usage was improved...I know my friends 2012 nexus 7 which had substandard quality flash memory started working very smoothly... This update is more under the hood but it still improves performance for us hopefully...
No it's under settings/developer options/root access/apps and ADB
I'm trying to install a custom boot animation from toolbox on a 4.3 ROM not working it said install failed. is toolbox not compatible with 4.3 ROM ? always work for me on 4.2 ROM
Ok so all the bugs I found are camera and gallery related:
1. Using HDR or Rapid Picture mode causes focal to crash and could not connect to camera error. Even if I use the stock camera app it says could not connect to camera. I have to reboot to get the camera back.
2. When taking pictures of even downloading pictures some show up as all black not picture at all. Doesn't happen alot, but it does happen.
