Root [MetroPCS/CDMA] [ROM][OFFICIAL] CyanogenMod 11 Nightly Builds for d2mtr
Like this ROM a lot. I changed my them and overclocked @1.836MHz with this Kernel: http://androidforums.com/metropcs-c...entropy-dns-tether-adblock-censor-bypass.html
It's responsive and quick. As for the camera i tryed the focal app but it has issue's when recording and locks up etc. I used this here for the gapps from shabbypanguine link he posted http://www.shabbypenguin.com/OUDstuff/Samsung/Metro/R530M/Random/Flash-2.zip. Since i have not seen it done I'm going to ad halo on it to see if it's more android user with the new CM 4.3 here: https://play.google.com/store/apps/details?id=com.paranoid.halo
So far good rom to mess with.
seems like the latest nightly not playing well with me lol cant use camera and also can restore backups from titianium backup
Same issues here too I can't backup with titanium too it's says insufficient space while I've available space 7.78gb on phone and 38.33gb on sdcard.
Ditto thought I was the only one. I'm on slim bean 4.3
But you got to remember 4.3 isn't official on the S3 and it could be just an in app issue that the developer hasn't updated yet...
This is what I did, I just create new titaniumbackup folder through root explorer on my sdcard1 and change the titanium backup storage path to sdcard1 on titanium backup preferences option, now it works perfect for me I can backup and restore with out any problem.
I had a very similar problem, and I read somewhere (sorry I tried looking for the forum I read it on but can't find it) that if you install the app lucky patcher and just run the app it will delete unused odex files. I did that I got a notification that it deleted the unused odex files and everything worked. Hope this helps
repeat of build.prop entries on d2mtr . persist.radio.snapshot_disabled and enabled
I see two entries on my samsung galaxy s3 . one with persist.radio.snapshot_disabled=1 and persist.radio.snapshot_enabled=1 . i think we should have only one selection
Thanks for your suggestion but I fixed on other way you can see on post #1363. Thanks again.
