Root [MetroPCS/CDMA] [ROM][UNIVERSAL][4.1.1 GalaxyMod
it doesnt say all versions, it says all MAJOR versions, as in tmobile, att, sprint, verizon and if us cellular is lucky enough to be included....
but im willing to bet a good bit of money metro/cricket/cspire are not on that good ole boy list...
Metropcs is on the list...And this rom has been mentioned in a previous thread...it's just that wifi and 4g didn't work...
If you get it working... Don't be no stranger. I told the dev of the rom about the metro issues like last month... Said he'll try.
He is asking how to fix the 4g WITHIN the rom not afterward the rom messes it up.
My link clearly says AFTER. He thought it was for within. I cannot be responsible for that. I explained a couple times that it's for after. I don't have a solution for within because I do not use this rom. If you do, feel free to share.
Just tried it out, 4g works out of the box, the only thing that doesn't work is wifi and I am pretty sure that's due to the kernel. I gotta say the smoothest jellybean rom I have tried so far.
sorry guys i can't answer before i try this and yes is metropcs support and work fine for a day but today my 4g died and don't come back i flash my backup (with jelly bean) and make factory reset and 4g come again
and i have TB so iam fine now but i have one thing special from this rom i take its audio hack (more volume) and is working great in jellybean
shabby iam not a dev but i think this hack will be available for all the only thing what need to do is change the file "snd_soc_msm_2x (what is in folder etc/snd_soc_msm) for the one inside of the rom in the folder alt/audio/hack/etc/snd_soc_msm i use es file manager to copy and fix permissions, reboot and yes is working
I don't now if you can do a flash zip for that I don't have idea how do that
swap the kernel use something like lean kernel.
hey how did you install the custom kernal? did you install the rom first or??
I flash this last night and its something to try out. I did flash the chemistry rom's metro fix and 4g was fine but now im just try to pull it together to give it a good test rather then x- ing it out.
Ok now I have tried everything, I flash the rom, flash the fix next flash kernal and rebooted...nothing
than I flash the rom, let boot at least once and cleared the cache/davik and flash the fix and kernal. I seen the kernal take but the fix only helped fix wifi. any thing Im missing here?
