Root [MetroPCS/CDMA] Stock/Clockworkmod
bcifer
Anyone had a copy of metro stock routed clockworkmod ?
deleted mine by accident.
Thanks in advance.
It's a lot easier for you to flash twrp (which is a 5mb file) and use the backup file available, then for somebody to upload a cwm backup (which is over a gb file). Faster too don't you think?
On the file provided here there are only 4 files, correct? I just could not get it to work.
Thanks.
You was rite. Got it to work. Had to re download the back up from here, I guess it got corrupted when I downloaded it.
Thanks.
