Root [MetroPCS/CDMA] [Theme][Metropolitan Theme for Metropolis Rom][v1.4.0]
ARocker
Android Expert
Aug 17, 2011
1,274
764
Jersey City, NJ
Please backup your phone before flashing this!
Flash at YOUR own risk!!!
Metropolitan is a Theme for Metropolis Rom 1.4.0 by Shabbypenguin in association with (OUDHS).
Based on Elegant Theme by ThilinaC
Including DCikonZ v1.1.5 Icon Set [APEX][NOVA][GO][ADW][HOLO][ATOM][TSF] by dcstudio.
For the full icon set try an app called Unicon. It allows you to use Many of the great icon sets available for other launchers, with our stock launcher!
Also Including SecLauncher2.apk 4x6, Screen Roatation and Wallpaper Scroll Mod by N4zty.
Elemets of SecMMS.apk MOD by dead-angel.
Also with Blue Glass MultiWindow Theme by whiskeybro. Stop by his thread for more colors and styles!
A partially themed Morphology Patch for Metropolitan is available so that you can use my theme as a base and make it however you like! It is the same patch created by Team noobz and rompnit and made available to us by nuttmeg and joshadaniels04 in the [Wipe][Auto Theme For Our S3] thread. I have added to the patch as many Metropolitan Theme elements i could port over. Anything not themed by the Metropolitan Patch can be easily done so with Morphology.
Please See Instructions for Special Flashing Directions!!
I did not create many of the images and files used in this theme although I have edited Too Many To Count.
Big thanks to Shabbypenguin and all of our devs and contributors!
Thanks to ThilinaC for letting me use his Elegant Theme as a base!
Thanks to N4zty for letting me use his Custom SecLauncher2!
Thanks to dcstudio for letting me use his fantastic DCikonZ icon Set!
Thanks also to nuttmeg, joshadaniels04, whiskeybro, dead-angel, blgblade, --anx--, Team noobz, rompnit, and KIMBASINGER for their great work!
This is their work, if you like it, donate to them!
This is my effort, if you like it, hit the Thanks Button and Rate the Thread!!
It works on my D2MTR, it should work for yours too.
I will update as I can. I'm not sure how far ill end up going with it.
I hope you enjoy it!
Please dont forget to hit the Thanks button and also please rate my thread!!
Metropolitan version 1.4.0 contains the following tweaks:
Tranparent Notifcation Pulldown Menu!!
Transparent MusicPlayer Widget!!
SecLauncher2 4x6 w/Scrolling Wallpaper Mod!!
MusicPlayer.apk
SecBrowser.apk
SecCalculator2.apk
SecContacts.apk
SecMms.apk
SecPhone.apk
jobmanagerui.apk
secsettings.apk
framework-res.apk
systemui.apk
ClockPackage.apk
New Screenshots:
Old Screenshots:
Installation Instructions:
For Metropolis Rom v1.4.0 [100% Stock]
-Copy Theme [Zip file] to sd card
-Boot to recovery
-Make Backup!!
-Flash Theme [wipe Cache & Dalvik Cache]
-Reboot & Enjoy
For Metropolis Rom v1.4.0 [Morphology Patched]
-Copy Theme and Themed Patch [Zip files] to sd card
-Boot to recovery
-Make Backup!!
-Flash Theme [Don't Reboot Yet!]
-Flash Themed Patch [wipe Cache & Dalvik Cache]
-Reboot & Enjoy
-You are now Morphology Patched and Metropolitan Themed (mostly).
WARNING!! No Need to flash the original Morphology Patch, that will untheme systemui!!!
Changelog:
Build 1.4.0 [8/01/13]
New Metropolis Rom v1.4.0 base!!
MusicPlayer.apk
SecBrowser.apk
SecCalculator2.apk
SecContacts.apk
SecMms.apk
SecPhone.apk
jobmanagerui.apk
secsettings.apk
framework-res.apk
systemui.apk
Old Changelogs:
Build 1.2.0 [3/23/13]
New Metropolis Rom v1.2.0 base!!
Big Weather Lockscreen Mod 1.2.0!!
Transparent Status Bar!!
Custom Transparent AccuweatherWidget Mod!!
SecLauncher2 w/Scrolling Wallpaper Mod!!
Custom Aurora2 Live Wallpaper!!
Updates, edits and color corrections
Added more custom pngs
AccuweatherWidget.apk
Aurora-signed.apk
MusicPlayer.apk
PopupBrowser_NOTEII_v1.3.apk
SecBrowser.apk
SamsungCamera.apk
SecCalculator2.apk
SecGallery2.apk
Gmail.apk
SecContacts.apk
SecMms.apk
SecPhone.apk
jobmanager.apk
phonesky.apk
secsettings.apk
framework-res.apk
systemui.apk
Beta Build 1 [1/13/13]
Updates and edits.
Made it more like original theme.
Added custom pngs
Notification background transparency.
Metropolis Rom v1.0.3.
clockpackage.apk
jobmanager.apk
stk.apk
phonesky.apk
secdownloadproviderui.apk
secsettings.apk
framework-res.apk
systemui.apk
Alpha Build 9 [1/10/13]
Updated
Fixed dark background issue
Metropolis Rom v1.0.4.
framework-res.apk
systemui.apk
Alpha Build 4 [1/10/13]
Initial release
framework-res.apk
systemui.apk
Upvote 0
As far as i can tell, so far there shouldnt be any major issues. The only thing i can find is this:
Its a font color issue which i guess requires editing of xml or i think the back ground should be light in color.
Also need to find the apk that the signal pngs are comming from. It dosent seem to be the two ive themed, even though theyre in there. Maybe twframework.apk?
Thats for tomorrow. Err later on i mean.
Upvote 0
I was trying something but I unzipped the whole rom because I'm not really familiar with making a flash able zip.. I was waiting for it to finish zipping the romantic back up when I came across yours... Now their not my images just stuff I found looking around This is what I got
Upvote 0
I like what youve done. The dark blue is nice and i like settings icons. You should post it.
Looks like youve edited systemui as well as framework. thats good. i dont know what advice i might give you as im just a beginner at this myself. I know theres a proper way of decompiling and such and there are tuts explaining how to use various command line apps. Ive never been able to get any of those to work out. So i just use 7zip to extract the folders, swap pngs and pit the folders back in the zip and test it. I used to use a website called uotk to theme gingerbread but never released any. It made it very easy to theme. Wish it was updated.
Best advice i can give is to pay attention to the names of the pngs. The names cant change at all. Also, youll see the same pngs in multiple apks.
  • Like
Reactions: mike28
Upvote 0
I have a whole bunch of colors...it's like 30 combos And actually what I put up is only editing system ui and settings... I haven't been able to get framework right.. Get a hold of me on gtalk
Ea.zepeda25@gmail.com and maybe we can work on it together....
Upvote 0
Sounds good. Only i gotta setup and download gtalk. Ill contact you soon.
Upvote 0
BEST TECH IN 2023
Smartphones
