Root [MetroPCS] Data issues CM11
So i have a question. Im running CM11 and my LTE is terrible..im not sure what to try. Is there an updated PRL i can flash? Maybe a modem? Before i rooted and flashed i never had these issues...any suggestions?? Thanks!
The Baseband version is M919NUVUAMF2? That's what you're looking for right? I called metro thinking they changed my coverage/plan or something but its still the same...
Having MF2 means you are on the old bootloader and you can update to the new 4.3 MK5 or NB4 modem from T-Mob: Then you have three options:
1- Flash 4.3 MK5 modem from Metro
2- Flash 4.4 T-Mob NB4 modem
3- Flash MK5 Firmware but you get new bootloader with Knox, not CM11
Both. NB4 is a a firmware and like all firmwares include bootloader, modem, EFS, kernel, system and data. You can only flash the modem or the whole firmware. ROMs generally include system and data, some of them have kernels too but do not include modems, EFS and bootloaders.
So i found this... [MDL Bootloader Only!] How to flash 4.4.2 NB4 Modem - xda-developers
Will this be ok to do with CM11?
**Update: It Worked
I think I had the same problem as you. Were your speeds slow like you ran out of the data you paid for?(the 500MB or the 2.5GB)
