I do not know what did wrong some days ago...
Everything works perfect, all apps, ... then "...gapps.com stopped" then everything fails... turn off phone, on again, all working perfect again, but just a while, sometimes works ok a few mins or several hours.
I tried all this:
wipe cache & dalvik
enabled usb debugging
changed opensource superuser by su
tried several busybox versions
changed stock launcher by nova
updated all apps
This is my environment: LGMS50010i, 32GB class 10, SdCard Memory Hack (4GB internal ext4 with 2.96 available & 26GB external FAT32 with 12.7 available), Voltage Control (384-972, cfq, interactive), AdAway, ...
Take lot of time start from zero again but my only concern is I do not know what did wrong, so will do it again probably.
Thanks in advance.
update: 20 hours without any issue... will post what I think is the solution when reached more time ok...
I tried all this:
wipe cache & dalvik
updated all apps
Thanks in advance.
