The CM11 build needs a lot of ramdisk work
here is a utility that can pack a ramdisk and zImage and then Loki it so that can be flashed, this should make it a lot easier for people to join in and get the ramdisk finished
also if you want to compile new kernel zImages with the kernel source, you can use this utility to pack the new zImage with the ramdisk
there are 4 ramdisks
CM11 - cm11
TWRP - twrp
Stock JB (500) Boot - boot-stk-jb
Stock KK (505) Boot - boot-stk-kk
Stock JB Recovery - recovery-stk-jb
There are 3 zImages
zImagecm11, zImagejb, zImagekk
You need a Linux computer
unzip f6_packer.zip to your home/user folder
To pack the cm11
open terminal
cd ~/f6_packer
./cm11pak.pl cm11
To pack the TWRP
open terminal
cd ~/f6_packer
./recpak.pl twrp
To pack the Stock JB recovery (not sure why you would do this)
open terminal
cd ~/f6_packer
./recpak.pl recovery-stk-jb
To pack Kernel for Stock JB ROM
open terminal
cd ~/f6_packer
./stk-jb-btpak.pl boot-stk-jb
To pack Kernel for KK PORT ROM
open terminal
cd ~/f6_packer
./stk-kk-btpak.pl boot-stk-kk
https://www.mediafire.com/?j76enwmdrdu4l1l
Thanks to
djrbliss for Lokie
If I have helped you, and you like my work, please click on the Thanks Button and give my thread a rating by clicking on the stars above.
If you would like to buy me a beer, you can click on the PayPal button
.hK
CM11 - cm11
TWRP - twrp
There are 3 zImages
To pack the cm11
open terminal
cd ~/f6_packer
./cm11pak.pl cm11
To pack the TWRP
open terminal
cd ~/f6_packer
./recpak.pl twrp
open terminal
cd ~/f6_packer
open terminal
cd ~/f6_packer
open terminal
cd ~/f6_packer
Thanks to
djrbliss for Lokie
.hK
