Root [MetroPCS] [MS500] Freedom Kernel Overclocked **Updated 6/17/15**
Kernel Updated
New Changes:
  • CPU overclock to 1.728 ghz
  • GPU overclock to 480 mhz (graphics)
  • CPU underclock to 144 mhz
  • New governors: Adaptive, Lazy, and Badass
  • New schedulers: SIO, VR, and FIFO
Screenshots:
All my benchmarks were conducted with the following settings:
1.728 ghz overclock
min set to 384 mhz
ondemand governor
cfq sheduler
I posted some reference profiles in post #5 for you guys that may be unsure of what settings to use. You can use these profiles as a base to get an idea of what settings to set.
When There's Freedom, There's Potential...
Freedom Kernel
For firmware 12b
This app can install the kernel and change kernel settings. It can also monitor system and kernel parameters.
Freedom Kernel features:
  • 1.728 ghz CPU overclock
  • 144 mhz CPU underclock
  • 480 mhz GPU overclock
  • 1.3 ghz L2 cache boost clock - details
  • Unsecured
  • Loki'd
  • Frandom built in for increased speed - details
  • Android TRIM Support - details
  • Conservative governor
  • Adaptive governor
  • Lazy governor
  • Badass governor
  • Intelliactive governor
  • Intellidemand governor
  • Wheatley governor
  • SIO scheduler
  • VR scheduler
  • FIFO scheduler
  • Init.d support - details
NOTE:
Run your benchmarks when your phone is "not" plugged in to power or usb to get accurate benchmarks.
Download & Instructions
Changelog in second post.
If you like my work and want to show some appreciation, please click the like button. :)
Enjoy! ;)
Will this work for the optimus l70? Thanks
Oh OK. Thanks. By the way GT, is there any chance of getting a Rom that unlocks our 4GB internal memory?
That's not gonna happen. 4gb is the combined size of the system, boot data, recovery, bootloader, radio, and all other partitions. Increasing the phones internal storage would require resizing all of these partitions and would be risking bricking the phone for an increase of 500MB or less. It would also require a special computer program that to my knowledge isn't available to the public.
After latest update My phone Lags like hell when playing Clash of Clans. Also I have experienced 2 freezes while Playing. I don't know why .
I noticed that my GPU are underclocked to 320mhz. Mmm I remember before the update It was always at 400mhz
Here are my setup
If this helps
The lag appears when I play more than 10 minutes , I close the Game and the Lag remains for 30-40 seconds And disappear But If I continue playing with the Lag , Then the phone Freezes and I have to take out the Battery.
What setting did u use to get the 20045 ?
I have only hit 20,000+ once. For that bench I had the following settings. Note, these settings consume a lot of battery.
1.7 max
384 min
performance gov
cfq scheduler
I know the cfq scheduler is not for benchmarking, but if you get a good/lucky run with it you can get some high benches.
Kernel Updated
Changes:
  • Set SD read ahead back to normal to prevent lag on low quality SD cards.
Google play store should push the update to you guys soon or you can keep checking yourself till it becomes available.
Is there a way to keep the increased read ahead speed since my sd card performs better with it? While continuing to update the kernel
