S stark4 Newbie Aug 25, 2014 #1 I just rooted my phone using Towelroot. I also installed SuperSU. Now can i uninstall Towelroot now? or is it gonna mess-up my root? Thanks btw do i also need to install busybox? Some instructions said to install busy box and some don't so I'm a little confuse. Thanks
GameTheory Android Expert Aug 25, 2014 #2 Yes you can remove towelroot after you have rooted. Yes you need busybox since many root apps require busybox. https://play.google.com/store/apps/details?id=stericson.busybox It should also go without saying that you need SuperSU as well.
