Im wondering if anyone has info on where software wise this cap is coming from. The modem maybe? Or the prl? Id like to look into how to remove the cap if possible.
Baseband? Doubt it, when did they update all the phones then?
Prls? Maybe.
Server Side @ Metro? Most likely....hopefully not....
You could always try thr baseband/prls tho.. i wish you luck on your journey borai!
