Please let us know how this ac power adapter works out for you once you receive it. Thanks!
Also, has anybody ordered long micro-usb cables from monoprice and how does these work for you charging the device? It seems that with micro-usb cables its hit-or-miss.
just tested out my monoprice micro hdmi, works but is loose on the the droid x port. thought i just need to give a little more push to get it to lock it but no luck. For only $5.88 each when QTY 50+ purchased - 10FT 34AWG Standard Speed w/ Ethernet Micro-HDMI (Type D) to HDMI (Type A) Adapter Cable - Black | Micro-HDMI to HDMI Cables the cable i bought. anyone know if i was supposed to get another one that fits better?
I just got my Monoprice micro HDMI yesterday, and had the same problem. It looks like a quality cable, however, It is too loose and you have to basically hold it in place and hope it doesn't disconnect. I'm not sure if it is an X problem or a cable problem. Let us know what you find out with the verizon cable.just tested out my monoprice micro hdmi, works but is loose on the the droid x port. thought i just need to give a little more push to get it to lock it but no luck. For only $5.88 each when QTY 50+ purchased - 10FT 34AWG Standard Speed w/ Ethernet Micro-HDMI (Type D) to HDMI (Type A) Adapter Cable - Black | Micro-HDMI to HDMI Cables the cable i bought. anyone know if i was supposed to get another one that fits better?
Thats werid cause I bought one and it didn't work at all. It charged my buddies phone but not my X?They work great, I've got about a half dozen of them.
