Hi there,
i got an unlocked Wildfire handset about a month ago. everything was fine, i was enjoying very much the phone when suddenly one day all my pictures and music disappeared. My phone showed me a message about some kind of problem with the micro sd card that may be solved accepting to reset the sd card. so i did. Then i got my sd card empty for about a week (no time to fill it up with music or anything those days...) and then, 5 day ago i got a little SD card icon with a little question mark (?) in the notifications bar. when i check it says: "REMOVED SD CARD - SD Card Removed. Insert a new one." - But the card is actually there!!!
I tried turning off and on the phone and nothing, the same removed-card message. So what i did, in order to rule out the possible damage of my sd card, was to insert a friend's sd card from his fully working htc desire and actually putting mine on his... the result: my sd card worked perfectly on the Desire but my friend's sd card got the same removed-card message on my wildfire.
What can i do? could this problem be hardware related? is my beloved phone broken already??? has any one have the same problem??
thanks in advance!
thanks in advance!
