Help micro sd help
agilep
i had a 2gb micro sd card in the htc then i bourght a 16 gb micro sd and i exchanged all the data onto the 16gb micro sd and i put it in my htc and all of the apps wouldnt work does anyone know what to do?
If you put the 2gb card back in do the apps work again?
If you copied everything from the 2gb card to the 16gb card exactly as it was, everything should work. I did the same thing when I bought my 16gb card. The most important folders for apps are /Android and /.android_secure.
Same prob here, looks like a dodgy sd card, did you get it on ebay? I tried another card and it works fine.
Hey Guys
Just upgraded my SD card,had problems first off, turned out the new SD card was preformated as FAT32. reformated it in the phone as FAT (setup, SD and phone storage,unmount then erase) then copied everything over to the newly formated card.
and BINGO
hope this helps
Leith aka Bundy
