Accessories Micro SD Question, need help
HTC Ryan
hello. question, which one of these memory cards would work on the HTC Incredible...?
New 32GB TF Memory Card 32G Micro SD SDHC MicroSDHC TF - eBay (item 170548212370 end time Oct-13-10 05:23:03 PDT)
my issue with this is that it says in quotes...
"Compatible with microSDHC host devices; not compatible with standard microSD-enabled device/readers."
i do not understand what that means...?
SanDisk? 32GB 32G microSD microSDHC SDHC SD Card **Bulk - eBay (item 150497448673 end time Oct-23-10 02:50:59 PDT)
S3T 32GB SANDISK MICROSD MEMORY CARD MICROSDHC SDHC 32G - eBay (item 280534921899 end time Oct-12-10 21:47:47 PDT)
and whats the difference? why is one like 18 bucks, one 55 and one 100?
Don't buy them off eBay. Only buy memory cards from trusted sources. There are a lot of fake memory card sellers out there.
Both normal SD and SDHC will work. But like pyro said, the ones on ebay might be fake. It's difficult to tell a real one from a fake one.
I bought 32gb tf memory card 32g micro sd sdhc microsdhc from ebay and to get it to even show up on my evo I had to reformat it and even now it wont let me play most video files. not sure why if its fixable but my 16gig scandisk I bought from radio shack has worked with out a problem
gues I got screwed out of $16 felt it was worth the chance :(
Can anyone suggest a price effective 16gb or 32 gb micro SD?
Flashing a few ROMs filled up my 8GB.
Do we need class 4 or better?
Anyone with a suggestion (link) would be appreciated!
Newegg has some good ones at good prices. I have 8gb and it's filling up quickly also, keep having to clean it up.
