Help Micro USB Orientation
lexluthor
Android Expert
Can one of the few of you who has a Droid X let me know the orientation of the Micro USB port?
I'm thinking of getting a right angle (or left angle) micro usb cable and I want to make sure I get one where the cable runs down towards the bottom of the device.
I'm pretty sure that the Moto Droid and the HTC Incredible are oriented differently.
Which way is the X's?
basically the same place as the incredible.
Not the location, the orientation. In other words, which way does it plug in?
It's my understanding that the original Droid and the Incredible Micro USB ports are 180 degrees different from each other.
I need to know which way the X's is.
This should suffice...
Looks like it is identical, in orientation to the Incredible.
Honestly, I'm not sure I can tell from those pictures. The ports look a little different even.
Also, remember the droid is on it's back there and the X is on it's face.
I kind of think they look the opposite orientation.
Anyone know for sure?
That site is expensive.
I got a 6' startech cable at buy.com for about $11 shipped yesterday.
It's the correct orientation.
