This is a STOCK ROM Backup which any MMX A25 Smarty Holder can use to RECOVER HIS OR HER PHONE FROM WORSE Cases, as i have also passedfrom a stage like this where i flashed Clockwork Mod-hence my a25 HANGED ON BOOT SCREEN(micromax/smarty).. so i decided to add this thread to help all others who arein need of this to recover there phones...!
As u have flashed ur a25 with WRONG ROM OR Clockwork mod which is not DONE PROPERLY THEN TO RECOVER FROM IT and To DO IT BY JUST SITTING AT HOME NOT GIVING TO MMX CUSTOMER CARE
,JUST FOLLOW THESE STEPS...
IMPORTANT THING- I AM UPLOADING 'clockworkmod' folder u just copy it to root directory of SD Card,then.....
Steps to Recover:
1.As this is a NANDROID BACKUP to recover-Flash ur phone with Clockwork Mod Recovery (link-http://forum.xda-developers.com/showthread.php?t=2063712).
2.then paste this BACKUP in your SD Card (not in any folder).
3.then boot into CWMR recovery by pressing-Volume Up + Power Only(no need to press home button).
4.Now click on-Wipe Data/Factory Reset , then select Yes, after Process completes click on-Wipe Cache Partition, again select Yes then....
4.then go to Backup and Restore option, then click Restore, then it will show you MY Backup FILE Stock Rom,CLICK ON IT, then many NO options will be there YOU HAVE TO CLICK ON YES.
5.then the restore process will start, u sit back let it do its WORK then CWM recovery will automatically reach its home screen, and u will see that below it is WRITTEN-SUCCESSFULLY RESTORED...
Thats It ,Now Reboot ur Phone n enjoy Installing custom Roms now without any worry as if ur A25 IS BRICKED U CAN RESTORE IT AGAIN TO ITS ORIGINAL STOCK ROM...
and wait my NET IS SLOW WILL UPLOAD STOCK ROM SOON.....
,JUST FOLLOW THESE STEPS...*
Steps to Recover:
