B Brianm109 Member Mar 17, 2011 #1 Does the TB take a different Micro SD then the Droid Eris? And wasn't I to have one already pre installed when I bought the phone?
willdogs Android Enthusiast Mar 17, 2011 #2 Same as the Eris (MicroSD) Yes it should be installed. Pull out the battery and it will be toward the top of the battery compartment. It should be 32GB MicroSD card,
B Brianm109 Member Mar 17, 2011 #3 willdogs said: Same as the Eris (MicroSD) Yes it should be installed. Pull out the battery and it will be toward the top of the battery compartment. It should be 32GB MicroSD card, Click to expand... Its not there.
L lewblue83 Member Mar 17, 2011 #4 Go to settings/SD& phone storage. Then see if the phone has the SD card. Should see something like 29gb available.
willdogs Android Enthusiast Mar 17, 2011 #5 Brianm109 said: Its not there. Click to expand... Maybe this will help. From the manual: 1. Take the Battery Out Then See Below: Uploaded with ImageShack.us
