m4p
Hey all,
Just got the Optimus Slider and want to get a bigger microSD card than the 2 gig one it comes with.
Would you guys recommend going with a 16 gig or would 32 gig be better. I plan on storing apps on the card, as well as pictures and videos.
Reading the manual for the Slider, it says make sure to use a recommended microSD card for the phone, but they fail to tell you what a recommended card would be.
Specifically, is buying a Class 10 card a waste, or can this card support Class 10. If not Class 10, what class does it support? Also, can it support a UHS-1 card?
Basically, I want to know what is the best specs this phone will suport.
Thanks very much for any help.
