UserMcgillicuddy
I have been using a SanDisk Ultra Plus 32 GB Class 10 MicroSDHC card for a few weeks with no problems. Yesterday I transferred all the data from the card to an external hard drive, so I could partition the card for use with Link2SD. The first partition is in Fat32 and the second in Ext4.
After partitioning the card, I transferred all the data from the external hard drive, back to the card. Upon inserting the card into my phone, it recognizes that there has been a card inserted (a notification pops up that says "SD card inserted"), but it behaves as though there was nothing in the card slot. For instance, when going to Settings>General>Storage and scrolling down to the bottom, under "SD Card" there are two grayed out options. The first says "Mount SD card" while the second says "Erase SD card." As both of these are grayed out, pressing or long-pressing does nothing. Upon removing the card there is a notification that says "SD card removed." Pressing this, or the above-mentioned notification, clears the notification and pulls the notification bar back to the top.
I have tried the following:
-remove/reinsert card
-restart phone
-completely power off/power on phone
-power off phone, remove battery, wait 10+ seconds, replace battery, power on phone
-reformat both partitions
-format first partition in NTFS, then Ext4, then back to Fat32
-merge partitions into one Fat32 partition
-completely delete partitions and reformat with default settings
No matter how many times any of the above are done, each time seemingly yields the same result. I have an older no name 16 GB Class 2 MicroSDHC card that I have used in every phone I have owned up until a few weeks ago. This card, when inserted into my LG L70, is recognized immediately. So I know the phone is capable of mounting a card, but for some reason it won't recognize the SanDisk anymore.
The first time I put it back in after partitioning the card, I was unable to explore the files/folders through Root Browser, but was able to create a new folder. So for some reason I could write to the card through Root Browser, but all the other data was unaccessible. Couple this with the fact that the card behaves completely normal when inserted into my laptop, and it makes me even more confused.
-restart phone
