MicroSD Cards
gedster
I'm considering getting an Xperia T but want to check whether it will recognise a 64gb microSD card? I know the official line is only 32gb cards work, but that isn't enough memory for me, so before I go and get the iPhone 5 64gb I'd like to check if any owners of the Xperia T have managed to get the larger memory card to work. If you did, is it a class 6 or class 10 and did you need to format it in the phone?
Thanks in advance!
I have an Xperia T and currently use a 64gb Micro SD card with it.
There have been no problems with it so far. I just put the card straight in the phone and it formatted it. Then I started using it!
So go ahead and buy the Xperia, you won't regret it!
The card in question:
Sandisk Ultra 64GB Class 10 Micro SD Card with SD Adapter: Amazon.co.uk: Computers & Accessories
Screenshot of storage capacity:
