Seinen
Hello everyone!
I recently got a Samsung microSD 64 GB class 10 card and thought I was fine for life to put whatever I wanted in it... how wrong I was!
I started copying various movies in it, to have them always available and I noticed that after 6 or 7 movies the rest become corrupted! Every time!
I tried everything, starting from changing the card's format from exFAT to FAT32 then to NTFS (and installed an NTFS mounter in the last case) but nothing... after 6-7 movies they still become corrupted (I used both an SD card adapter+reader already existing in my laptop, an USB adapter and even the USB cable via the mobile)!
So after some extensive googling I found that others have had the same problem also (in this forum too) and what they found is that the card's root directory has a file number limit and thus the solution would be to create many subfolders.
Thing is, while I tried copying in the root directory too, the very first attempt I did was copying a whole movie folder in the card, so I had a subdirectory from the very beginning and it didn't work!
I don't know if it has anything to do with the fact that it's a class 10 card, I read that the smaller the class the better the card, but I figured that it would be a matter of reading/writing speed, which I don't mind being low... but not being able to copy a large number of files, which is what I paid for, is a truly enraging matter.
With only 10~something GBs of movies being able to be copied in the card everytime, it makes the remaing 50 GBs of the card useless, dammit!
If anyone has a solution to offer, I would truly appreciate it! :smokingsomb:
