I have a Lincoln Navigator w/ Sync. I connect to "services" select navigation, answer the "where do you want to go". Then erractically the GPS will give location. (more often fails than gives)...Sync then says downloading if it gets the car location, but then nothing happens. I have waited 10 minutes with the car saying "downloading". It has failed on two droids but works on other phones...any suggestions?
Thanks
Thanks
