Accessories Mid-range extended battery
fiendslyr
I was wondering if there is a mid-range extended battery for the epic? Something along the lines of 1800 mah, so the phone doesn't need an aftermarket back cover. I looked around and only found 1600 mah and I don't think that would make much of a difference. Thanks in advance for any help.
The 1600mAH is the only extended battery that I personally know of that will fit the stock door.
