Root Midnight Random Reboots
fogle7
Member
I've been with this rom since the beginning of time, some of the past version have had this rebooting issue, but that last 4-5 updates have been really stable.
Now the current version constantly reboots. It is as bad as some of the unstable releases.
I had 6 reboots yesterday and one this morning. It's getting old. I have not messed with anything rom related, besides installing a custom font, which back on the other versions caused didn't cause any problems. I have not even touched the kernel tuner, everything is pretty much at stock midnight.
Anyone know anything that might prevent the random reboots?
You didn't really need to create a new topic, you could have posted in the MidnightRom thread. If you know a previous version works for you, then you could always try going back to that one. Other than that, you might want to try a reflash or try uninstalling kernel tuner (I remember way back when I used Midnight, that solved a few problems).
