Root Mik3D Wimax notification light
hove131
Does it work with this ROM ? It worked with MIKG just fine ... but I cant get it to work on MIK3d. The test mode works just fine when Im in the wimax notification application. I am using GO SMS Pro though ... is that the issue ?
not sure never used the app(?) before. what is it doing that is not working? and i doubt that a messaging app could mess up an app for wimax notification.
The wimax led light wont flash when i get a message. The weird part is ... i turned the normal led notification off ... and it is still working when i get a text or email!!!!
