truthlesshero
so...
I know this has been posted a little while back by justajason... but since we've been able to get a 2.1 root sbf for pretty much all versions of the milestone...i was wondering about the possibility of apps2sd
i rooted my milestone, installed busybox (i think...everything seemed to go off fine...is there any way to check?) and i got the apps2sd apk and "installed" it...
i formatted a part of my sd card to fat32 and ext2...as far as my partition program says, it's partitioned like that
so i open apps2sd and it says that my card is not partitioned correctly and offers to fix it
so i click fix it, it says completed, then it asks me for a reboot, so i do
after i reboot, re-open the program, i get the same error message
so what doesn't work? is it the format of my card? do i need to do anything else to get apps2sd to work?
help!
thanks...
help!
thanks...
