Help Milestone Battery problems?
R-droid
I have some problems with the battery life of my Motorola Milestone.
The battery dryes out really fast.
-The phone was charging whole night.
-In the morning the battery was completely charged.
-After 6 hours (of not charging) the phone's battery was completely dry,even thought the phone was in sleep mode all the time and none apps were running,but the battery was out.:confused:
I have no idea why this happened. (it's not the first time)
Anyone knows anything?
Can someone help me here?
An app must have done that. If you have any apps that auto-sync and do not have coverage they may try to sync endlessly without eventually succeeding because you have no coverage, no data plan or for some other reason.
in My case, Milestone charges reaaaaaly quickly, and start discharging quickly too. it is less than 1 year old and am i to change the battery now???
Try discharging the battery and charging to full a few times to recalibrate it.
You could download the app 'Spare Parts' and check if your phones are ever going into sleep mode. If 'Running' (Battery History) is at 100% it is an app that's keeping your phone from sleeping. To find which one it is you can use 'Watchdog'.
