Help Milestone not recognised by Mac OS X?
lilac
Hey guys,
Was just wondering if anyone had any ideas. I have googled and searched these forums with no result.
My Milestone (2.1) has never been recognised by my Macbook (1st gen) since the day I bought it when I plug it in via usb. I have been interested in syncing my music on iTunes via doubleTwist so have tried again to connect my Milestone to my Macbook.
I have tried two different cables and my laptop doesn't recognise the phone at all. When I do plug in the phone the screen illuminates, but it doesn't actually charge the phone.
I have used 2 different microusb cables (the one that came with the Milestone and one that came with my partner's Desire) on each of the 2 USB ports.
FWIW I've also successfully connected two previous Nokia phones successfully to this same laptop.
I have successfully connected my Milestone via USB to my partner's Dell M1330 laptop running Windows 7 to do Android updates.
Conversely, my partner's Desire can be connected via USB and is recognised by my Macbook.
Is there any special driver out there I need to download or am I just screwed?
Thanks in advance,
lilac
can't you use an external card readers hooked up by USb? I have mac, and seems the phones I want won't download to mac via USB, and it's a macbookpro with no card reader, it has the extension slot.
the samsung (which I returned it wasnt a smart phone which I have decided I want) I tried prior the mac wouldn't recognize it by usb, I thought getting a card reader that reads all different sizes and connects via usb to download would
is this correct
thank you
