Mini Diary- Can I transfer my data?
lob
It was never my intention to start frequently using the preinstalled 'Mimi Diary' app. Had I realized that I would by now have around 70 or 80 entries, I would have used a more flexible alternative from the Market.
Does anyone know of any way, should I change phones, that I could extract that data from this app in a way that would allow me to read the diary, say, on my PC?
Thank you.
I know this is old, but it was a first hit on google. Anyway sqlite can read mini_diary.db. Maybe someone else has a less technical solution, but here goes:
root then browse to:
data/data/com.sec.android.app.minidiary/databases
copy mini_diary.db to a PC somehow (copy it to the DCIM folder the grab it with a USB cable like you do for pictures)
download the sqlite command line utility from SQLite Home Page
I made a folder called c:\sqlite> and put the files in here (sqlite3.exe and mini_diary.db)
c:\sqllite>sqlite3.exe mini_diary.db
sqlite>select * from diary
this will show the data
maybe some java programmer out there can get the jdbc driver and make a piece of source to extract to a csv then you can open with excel or libre
OK Guys try this.
You need root access.
Before you factory reset.
Go to dbdata--->data bases--->com.sec.android.app.minidiary---> copy mini_diary.db to your SD card.
Factory reset.
Go back in and replace the .db file with the one you saved and reboot phone and all should be well.
NB: if you get an error message saying "insufficient memory" when trying to write a new diary entry reboot your phone again.
I was so glad when this worked, I'm sure you guys will be too.
