Help mini paper
lochaos
Recently updated my gs2 to 2.3.4 and i cannot use mini paper anymore, if i press on it to write something nothing happens, now some people might think this is no big deal but i use it for reminders and lists for shopping, i have a memory like a sieve, if anyone can shed some light know this i would appreciate it.
Try other appz of same type. There s plenty o them in market and some are more useful. Yet i have no clue why its not working after 2.3.4 update.
You are right. Updated to latest version and mini paper does not work any long.
I will look at the the other apps, but would rather the bug was fixed.
I use it all the time.
Andrew
Did you get your update via Kies? I've never had a problem using mini paper with 2.3.4 or .5
Andrew
Found a fix....
Follow these easy steps..
1. Goto settings on your phone
2. Goto applications
3. Goto manage applications
4. Goto all applications
5. Scroll down list to mini paper, press mini paper
6. Press clear data tab
7. Smile because mini paper now works again
Having just got an S2 and updating to 2.3.4, I too noticed Mini Paper was broken. It never occured to me to run "Clear Data". Cheers lochaos.
Found a fix....
Works like a charm on my Galaxy S2 (updated to Android 2.3.5)
I sure hope someone can help me.I was playing around with my new phone and somehow I opened a few diff mini papers on home screen and cannot delete them.it doesnt even give me the option.how can I delete these? they are taking up room on home screen and very annoying.
