Dubbin1
Android Expert
So I got my Surface case, belt clip and dock from Seidio today. I wasn't sure I would like the dock since it isn't horizontal but after playing with it for a couple minutes my mind has been changed. Now I can have it sitting next to me and use my GN without having to remove it from the dock. It is a bit of a pain to get it to sit on the dock but I'm guessing with time I will get the hang of it. It also has enough heft to it so you wont have to worry about it tipping over.
Oh and the dock will work with or without the case.
seidioonline.com
On a side note I was able to put the case on with the extended battery and stock battery cover with no modifications to the case or the cover. I didn't even bother trying the back from the extended battery yet. The next time I need to remove the battery I'll give it a shot.
seidioonline.com
