MiniInfo has been acting weird.
I install it on the SD card, I switch off the phone and switch on I get "problem loading gadget". I cant find it on the widget in the list. (I have to then find it on the market uninstall and reinstall.) I install it on the SD card then move it to the phone same issue. Basically the widget doesnt work if the phone is switched off and switched on back or if the app is moved back and forth to sd card and phone. Anyone has a similar problem? I liked this app because it takes only 2 positions on the home screen and it has all what I need in one app. Dont think any other apps that's a good substitute to this one?
