I had the same problem. After looking around these forums I found out that most widgets cannot be run off the SD Card. Most likely Minimalistic Text is running off the SD Card. You'll have to install an app like this (App 2 SD Free (move app to SD) - Android app on AppBrain) to transfer an app from the SD Card to the phone and vice versa. Once transferred, the app should work fine, hope it helps
