Root Minor Issues after root
dopefedz
Hi all. Looking for a little help here. I just received a replacement EVO after having to send off my original rooted one 4 times for a speaker fix. I got the new one rooted and I have flashed Kings Ultra Black which I was using previously without any problems.
This time around there are various applications that I'm trying to download from the market but when I search them there are no results. Some of these apps i'm looking for are the Drag Racing game and Fancy Widgets Pro. Is there a reason why after rooting I cannot find these apps in the market but right before I rooted I was able to.
I'm also looking for the Sprint Navigation app which I think used to appear in a addon folder in the Ultra Black rom folder but I don't see the addon folder. Previously I would go there and run it or install it from there and then I would have the application again.
Any help is greatly appreciated.
which gapps file did you use? in the roms/kernel sticky there is the latest gapps file. also you can try going to the market on your computer and find the apps and it should download straight to your phone.
I believe that is a sense Rom and doesn't require the gapps zip. I'd wipe cache and dalvik cache. If that doesn't work, I'd completely wipe the Rom and reflash.
If its cm7 based, I'm a chode and do as ocnbrze said. :D
yeah i get mixed up when king names his crazy roms!!!! they are all ver similar between his aosp and sense roms. so not sure what is what anymore.
