Root Minor Problems after root
Rooted after the GB update using the process for LG Esteem. Simple and Fast! I was pumped! I'm a newb, obviously, so I was a bit nervous. Everything has been great. I've got the apps I need and everything. My question is this: If you delete something that is needed by an app, but not necessary for the phone to run, what will happen? Reason I ask is this, I went a little crazy deleting things, but I'm no programmer. I now cannot add a widget that is past a certain point through the home screen add. Is there any way to recover a minor file like that after it's been deleted?
i have rooted several devices. On the stock rom I never delete anything. I simply use Anttek App manager to freeze apps.
Do a factory reset then freeze apps you don't want
